1999 Lincoln Continental Fuel System Not Activating
130,000 MILES • V8 • FWD • AUTOMATIC
1959MGA1500
Turned car off in driveway, will not start. No DTC code present. No fuel pressure to rail. Changed the fuel pump and Crankshaft pos sensor. Still no pump action.
Power to pins 9 and 7 on fuel pump module. No pwr to pin 1.
Fuel injectors do not pulse. Manually applied power to pump and got gas and pressure to fuel rail. No pulse found at injectors with test light. No clicking sounds at any injector.
The ignition is working - had fire at two separate plugs.
Is there a common link between the activation of the fuel pump and triggering of the injectors. My next tests will be of these items. Any advice in the right direction will be appreciated.
MAF sensor
Camshaft Sensor
PATS system
Lighting Control Module ( This may be bad. The chimes, turn signals, etc do not work. My son's car so I don't know how long they have been out)
Jul 6, 2010 at 1:46 AM
DOCFIXIT
  • 18,828 POSTS
Hi Have you checked inertia switch drivers side "B" pillar behind access door? is there power to injectors on RED wire?
Let me know
Thanks for donate
Jul 6, 2010 at 4:13 AM
1959MGA1500
Thanks Doc,
Yes, I checked the inertia switch. Power from this switch to pin 9 of the fuel pump module has 12 volts as it should. (Pin 1 has no power - "enable fuel pump output" from pin 80 on the PCM)
Yes, I checked two injectors. Both had power at the red wire.
MAF sensor has power to it also. Have not checked any returns from the MAF.
Have not checked the Cam Pos Sensor, but on this Continental - doesn't the Crankshaft pos sensor trigger the PCM to allow the fuel pump to pump. Also, doesn't the PCM register the last cycle to time & trigger the fuel injectors. If so - what can cause a no trigger to all of them?
Lost in the woods - I am an old car shade tree but all I see are sensors and modules and do not comprehend how they all tie together.
Thanks
Jul 6, 2010 at 4:36 AM
DOCFIXIT
  • 18,828 POSTS
At pump module TERM 7 dark green /yellow wire is there voltage? Term 1 from 80 on PCM should provide ground.CMP signals spark and injector pulse.Is theft light on ? does it blink?
Jul 6, 2010 at 5:06 AM
1959MGA1500
Thanks again Doc,
Yes - Pin 7 at the fuel pump module has power
Theft light is not on at all. I suspect a problem in the lighting control module as there are no chimes, turn signals, etc. I have also not seen the red light that is supposed to come on for a few seconds and then go off for the PATS.
But to answer - the theft light is not on or blinking.
Jul 6, 2010 at 5:24 AM
DOCFIXIT
  • 18,828 POSTS
Your at a point where a scan tool is needed the PCM is not sending ground signal to injectors or fuel modual. Check for grounds at PCMon pin 3,25,51,77,103 this will tell if MAF,CKP & CMP are also grounded
Jul 6, 2010 at 6:08 AM
1959MGA1500
Ok, thanks for the help!
Jul 6, 2010 at 6:52 AM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Jul 19, 2010 at 5:48 AM
SVILLELLA
I had the same issue.
I unhooked the connector to the crankshaft position sensor and jumped it with a paperclip. Pump ran longer and then pumped while cranking.
Connected the plug back up and reinstalled the fuel tank.
Bam the pump runs to prime the systems and the car fired.
I had no fuel pressure. (pump wouldn't prime or run at all)
Inertia switch not tripped.
Jumped the two sets of wires at the fpdm (1and 2 9 and 10 i believe)
---The pump run no problem
---That told me i had no issue with power to the pump but wasn't getting the power to turn the pump on.
I unhooked the crankshaft position sensor cranked and the pump ran a little when the key was on. Then used a paper clip to jump and tested the pump it was pushing gas.
Hooked the crank sensor back up and now it runs.
Gonnna by a new crankshaft postion sensor and a new fuel pressure regulator (due to hard cranking to start before this issue.)
Thanks for your help guys!
Jun 8, 2014 at 4:37 AM
SVILLELLA
^^^^This was a 97 Continental^^^^
Jun 8, 2014 at 4:38 AM
