1998 Lincoln Continental Rear Passenger Brake Light
SMILES99
Electrical problem
1998 Lincoln Continental V8
I need to replace the rear brake light bulb. Can anyone tell me where to start. I do not see any where to remove any screws, just one long cable going into the firewall to the lens.
Jun 18, 2009 at 1:47 AM
MERLIN2021
  • 17,250 POSTS
Open the trunk, remove the plastic buttons that hold the trunk interior trim to the rear section, remove the trim, there should be a pigtail or two that twist off, pull the bulb out and replace. Install is the reverse.
Jun 18, 2009 at 9:04 AM
SMILES99
Actually after trial and error you have to remove 5 bolts. The entire light casing comes out and you then have to pull the light out to replace.
thanks anyway.
Jun 18, 2009 at 2:42 PM
