for the switch in thr trunk should it be off for it to work or on. and the air leveling work for tire or just the supension.???
Apr 15, 2010 at 1:14 PM
2CARPRO JACK
✓Experienced Mechanic
The switch in the trunk should be on if you want the air suspension to work.It is for the suspension, not the tires.
Apr 15, 2010 at 1:32 PM
BRANDON2010
MEMBER
i am not hearing the fan kick on but i am hearing the vents open . how i check to see if the fan is working or if it is unplug or hook up? or what else could be the problem
Apr 19, 2010 at 6:29 AM
2 LINSEY
hi brandon2010, are you still talking about the air suspension? If not which fan are you refering to and what exactly is your question?
Apr 19, 2010 at 7:50 AM
2CARPRO JACK
It is under the lower right side of the dash, you should be able to hear it
Apr 20, 2010 at 12:38 AM
BRANDON2010
MEMBER
the Fan or Blower is what I am talking about now
ok i ca no hear the fan. now i check the fues in the fues box under the hood and it is not broke or and anything . and the thermostat seems to work. could the blower be unplug or not hooked up by any chance??
also is the the blower part of the Safety for the car?
Apr 20, 2010 at 11:46 AM
BRANDON2010
MEMBER
the air leveling disabled. i check the switch in the trunk and it is on but i still get the air leveling disabled. could the be another reason why i am still getting this message?. i am also getting a low air warning for my tires buti check the levels and fill the all but i still get it. do i have to reset something or what?
thank you :)
Apr 20, 2010 at 12:15 PM
2CARPRO JACK
The system is disabled due to a problem, so it shut itself off.You would need to have the system scanned to see what is wrong.
The blower/fan you will need a test light to see if you have power at the blower motor.
Apr 21, 2010 at 12:37 AM
2CARPRO JACK
No problem.Those air suspensions can be a real pain to fix as well as expensive.If you decide its too much you may want to look at strutmasters.com to see what they have as far as air bag elimination kits.I have installed a few of them and they ride nice and dont break....LOL
Apr 21, 2010 at 11:11 AM
BRANDON2010
MEMBER
thank you
Apr 21, 2010 at 11:54 AM
BRANDON2010
MEMBER
Air Suspension diagram where would i find one. or could you tell me with the relay switch is for the compressor ?
May 2, 2010 at 2:57 AM
2CARPRO JACK
You can get a full schematic at the "car repair manuals" link in the left menu. The fuses for the system are 4, 11, 28 and the relay is located above the right cooling fan
