1997 Lincoln Continental torque converter clutch soleniod
1997 LINCOLN CONTINENTAL
93,000 MILES • V8 • FWD • AUTOMATIC
TRASHMAN16839
I got a code p0173 and code p1414 on my lincoln what is torque converter clutch circuit electical and what do i do to fix it and will it tell me to check traction control
Nov 12, 2008 at 12:04 PM
BMRFIXIT
  • 19,053 POSTS
Check fuses and relays
Air Pump is commanded off ,but PCM indicates AIR pump is on .possible causes are:
EAIR circuit open or short to power
Faulty solid state relay SSR
faulty electric air pump
faulty PCM
testing is needed to determine the failure and the cause
\good luck
Nov 15, 2008 at 2:44 PM
