1997 Lincoln Continental
TAVARISHAIRL
  • 1997 LINCOLN CONTINENTAL
  • V8
  • FWD
  • 88,000 MILES
Why want my car start? It says check charging system in will it be alot to repair
Tuesday, April 27th, 2010 AT 10:21 PM
BMRFIXIT
  • 19,053 POSTS
Ensure battery posts and cables are clean and tight. Check drive belt tension.
Ensure connections at generator, regulator and engine ground are clean and tight.
Check fuses and fusible links, replace as necessary.
Check condition of battery to see if battery has the ability to accept and hold a charge.
If battery capacity meets requirements, charge battery before proceeding with testing to ensure battery is fully charged.
NO-LOAD TEST
Connect voltmeter positive lead to B+ terminal on generator and negative lead to ground. Start and run engine at 1500 RPM with no electrical load (foot off brake and doors closed). Read voltmeter when voltage stabilizes. This may require waiting a few minutes. Voltage should be 13-15 volts.
If voltage increases to proper level, proceed and do a LOAD TEST. If voltage increases beyond proper level or If there is no voltage increase, suspect bad alternator
Saturday, May 1st, 2010 AT 10:17 PM
