1997 Lincoln Continental
DEELEEC3
  • 1997 LINCOLN CONTINENTAL
  • V8
  • FWD
  • 134,244 MILES
Were do you install a door ajar switch on the drivers side
Monday, March 1st, 2010 AT 10:50 AM
MERLIN2021
  • 17,250 POSTS
In where the claw on the door is, from inside, if you have a door ajar and the lights stay on problem try this first: Try this cure, buy a can of brakekleen and a can of spray white lithium grease, spray the latch area, thats the claw in the door where it closes, spray liberally with brakleen, open and close the door 5-6 times, repeat, then spray with the white lube, open and close the door 5-6 times. Reapeat on all doors.
Monday, March 1st, 2010 AT 10:55 AM
