1996 Lincoln Continental fuel
110,000 MILES • V8 • FWD • AUTOMATIC
MGSTUBBS
the gas spits back when I try to fill the tank, It will fill slowly from a gas can but cant get a pump to work.
have pulled the gas tank and it and the pipes are clean & clear. the fresh air hose from the canister to the engine is clear. It seems the tank is not venting whentrying to fill.
Jan 27, 2008 at 3:26 AM
BLACKOP555
  • 10,386 POSTS
Check the vapor valve on the top of the tank, also you may need new vapor lines or charcoal canister.
Jan 27, 2008 at 4:05 AM
MGSTUBBS
The vapor valve on top of the tank is molded?glued into the tank. Does someone make a replacement valve or does the tank have to be replaced. The lines appear to be clear when air is blown through them but it also appears there are 2 valves on top?
Thanks
Jan 27, 2008 at 7:04 AM
BLACKOP555
  • 10,386 POSTS
i believe yours will have to have a new tank. take it in and have a shop do a charcoal canister test.
Jan 27, 2008 at 10:46 AM
MGSTUBBS
Thank you for your help, I'll let you know
Jan 29, 2008 at 11:58 AM
