Ok with not knowing what problems you are having here is what I found in the wiring diagram. A blower motor relay, located in the power distribution box under the hood (owners manual should say which is which). Then there is the constant control relay which is located on the center of the radiator support. Thats all the relays. Now the constant control relay does have 4 relay's with in it (that can't be replaced seperatly) and controls the A/C clutch. Hope this helps.
Sep 25, 2009 at 2:47 AM
