1996 Lincoln Continental
FLEWILL2000
  • 1996 LINCOLN CONTINENTAL
  • V8
  • FWD
  • 197,000 MILES
The car ran hot one day out of the blue and then the temperature control went back down to normal. I was told that it was the water pump then it was the thermostat which was replaced still ran hot. Then I was told that it was the radiator and I had that replaced along with another thermostat. Still the car ran hot I don't know what else it could possibly be. Could you please help
updated 3/4/09
Thank you that is pretty much what I have been told but you were dead on.
Wednesday, March 4th, 2009 AT 9:48 AM
JAMES W.
  • 2,394 POSTS
First thought would be thermostat, but the chance of two replacement stats being bad is almost "nill". It sounds like you have covered most of the common causes of the problem. The next step I would recomend is having the cooling system checked for exhaust gases leaking into the cooling system. This condition will create air pockets in the system and won't allow the coolant to dissipate the heat from the engine block. There are kits available at most parts stores that will detect the presence of exhaust in the coolant. The most common cause of the problem is a bad head gasket or a cracked head. With close to 200K on the engine, I would suspect a gasket failure. Let me know what you find, or if I can help you further.
Wednesday, March 4th, 2009 AT 12:20 PM
