1995 Lincoln Continental shutting down at hi rpm
1995 LINCOLN CONTINENTAL
53,656 MILES • V8 • FWD • AUTOMATIC
BCR220
i just bought a 1995 lincoln cont. 53,642 miles great shape, old man owned it, today i was merging into traffic and hit the gas when i did that it started jumping and hesitating rpm's dropped to 1 and when i would hit the gas it would do nothing, if i feather the gas it kinda stalls then takes off and jumps some more, then started shutting off, so i was having to start it and throw into drive before it stalled out again, after finally getting onto the main road it was ok didnt stall anymore drove in the neighborhood and nothing abnormal, seems only happens when i hit the gas and rmp's go over 4000. please help thanks.
Feb 13, 2008 at 12:52 PM
MASTERTECHTIM
  • 4,750 POSTS
plugged fuel filter would give hesitation at high rpm, maf sensor also could cause this, try disconnecting maf and see if you can get higher rpm. check back to us.
Feb 13, 2008 at 12:59 PM
ALLBROWN
  • 27 POSTS
A my man ... I had the same problem B4 . It sounds like your FUEL PUMP !! Change it & set the hesitation free !!!
Feb 15, 2008 at 9:02 AM
BCR220
[quote:6910be1de2="allbrown"]A my man ... I had the same problem B4 . It sounds like your FUEL PUMP !! Change it & set the hesitation free !!![/quote:6910be1de2]
thanks for the input ill try it, whats the worst that can happen... thnx
Feb 16, 2008 at 5:38 PM
BCR220
[quote:0e2d254a2c="mastertechtim"]plugged fuel filter would give hesitation at high rpm, maf sensor also could cause this, try disconnecting maf and see if you can get higher rpm. check back to us.[/quote:0e2d254a2c]
i thank you for the input, i also thought it could be the maf sensor. ill replace both didnt know how costly it would be.. thanks for your help
Feb 16, 2008 at 5:41 PM
