1995 Lincoln Continental Oil leak
216,000 MILES • V8 • FWD • AUTOMATIC
GI_JOE2004
I have a small oil leak coming from the front passenger side of the motor and i can see where its coming from but dont know what gasket to get, its coming from where the ac compressor mounts into something else which mounts to the block. leaking from between the block and what the ac compressor mounts to. What gasket is that and how hard of a job is that? Also does anyone know where i can get an exploded diagram of my motor to see everything? Thanks
Oct 15, 2008 at 9:11 AM
JNOVACK
  • 723 POSTS
sounds like the valve cover gasket not very hard to change you removebolts holding cover on clean cylender head were gasket sits clean valve cover install using rtv (on edge of head and valve cover)gasket put bolts back in and torque to 17-20 inch pounds you can also get the repair from the link at bottom of my post
Oct 19, 2008 at 11:40 AM
