1995 Lincoln Continental changing a headlight bulb
1995 LINCOLN CONTINENTAL
140,000 MILES • V8 • FWD • AUTOMATIC
NIKONF5
MEMBER
1 POST
how do you change the headlight bulb(bulb only)in a 1995 lincoln continential?
Dec 9, 2007 at 1:37 AM
MERLIN2021
✓Experienced Mechanic
Open the hood, find the back of the headlamp, there is a lock ring, pull the connector off the bulb, unscrew the ring, pull out the bulb! Install is the reverse...
Dec 9, 2007 at 1:41 AM
JESPANA
MEMBER
Easyer way, on the headlamp there are two sliver metal bar/tabs. They go into the headlamp to hold it into place remove them and the headlamp will come out easy and you can replace the bulbs a heck easyer.
Apr 10, 2008 at 7:49 AM
MERLIN2021
I sorta think this one's already been changed...thanks for the help tho...
Apr 10, 2008 at 8:37 AM
