1995 Lincoln Continental Auto Temp Control
1995 LINCOLN CONTINENTAL
117,000 MILES • V8 • FWD • AUTOMATIC
FITCAROL
Hello-
My defrost, heat, basically all of the temperature control settings stopped working a couple of weeks ago. I don't understand what the problem might be. Do you have any ideas?
Jan 12, 2009 at 2:05 PM
ALLBROWN
  • 27 POSTS
I to have had this issue b4 . Pop the hood & take a look
@ your passenger side firewall . Right up under your cabin air filter should be a hose ... inspected it for holes or to see if it's still connected to the line entering into the firewall. That lil stinker helps the vac pull into your vents ! Good luck fellow wrencher
Jan 31, 2009 at 6:18 PM
