1995 Lincoln Continental air leveling
TMORAVEC
Suspension problem
1995 Lincoln Continental V8 Two Wheel Drive Automatic
my front passenger air suspension is acting up is there a sensor that i can replace
Mar 6, 2010 at 9:19 AM
ERNEST CLARK
  • 1,730 POSTS
There is a sensor "Ride-Height" that controls the adjustments of your suspension. You'll have to test this sensor before assuming it's bad.
You could also have a leaking air line or malfuntioning pump.
If you plan on doing your own work, write back and I'll walk you through the procedures. If not, take your car to a qualified shop.
Mar 6, 2010 at 10:21 AM
