1994 Lincoln Continental Stalls when AC
123,000 MILES • 6 CYL • FWD • AUTOMATIC
FINEOFAMERICALUXURY
My 1994 Lincoln Continental stalls when I use my AC for any extended periods of time. Typical it will drive for an hour or better but will eventually shut off either driving, in park, or coming from a stopped position. The system never shows any form of overheating. After I cut the AC off and leave the car off for up to 30 minutes, it drives like a champ.
Also if the car is on and in park for too long, it will shut off. Usually it will start back up after 5-minutes.
My battery is strong, terminals in good condition, and the battery cables and heads are good.
I paid to have it diagnosed but was told everything was fine. But it is obvious that it's not. Please help if you can.
Sep 6, 2009 at 3:18 AM
BMRFIXIT
  • 19,053 POSTS
After engine stalls check for spark if no spark suspect bad module
if you have spark and fuel suspect and replace IAC valve
Sep 8, 2009 at 1:01 PM
