1994 Lincoln Continental keylesspadentryproblem
1994 LINCOLN CONTINENTAL
165,000 MILES • 6 CYL • FWD • AUTOMATIC
JOHNRFOTO
can a keypad be reprogramed, and is it terribaly difficult
Nov 2, 2009 at 5:35 PM
BMRFIXIT
  • 19,053 POSTS
No need for any programming is just replacing the pad
but if adding remote this is how
REMOTE TRANSMITTER
NOTE:For additional information on remote transmitter programming and trouble shooting, see REMOTE KEYLESS ENTRY DIAGNOSTIC SERVICE TIPS bulletin (Ford Bulletin No. 97-24-13) in TSB.
To program (or re-program) transmitter(s) into the remote/keyless entry module, perform the following steps:
Turn ignition switch to ON or ON/ACCESSORY position and momentarily short the two terminals of the Program Connector (J4). The Program connector is a 2-pin connector taped to the wire assembly. It is located to the right of the glove box, behind the far right side of the instrument panel. All doors should lock then unlock. Remove shorting terminal.
Press any button on transmitter. All doors should lock then unlock, to verify that transmitter has been programmed.
NOTE:If door locks do not respond, press button again (up to three times maximum with the same transmitter). If door locks still fail to respond, go to symptom test.
Go to step 2 to program additional transmitters into the control module (up to four transmitter maximum).
Turn ignition OFF. All doors should lock then unlock.
Check operation.
NOTE:The remote/keyless entry module erases all previous transmitters from memory when the transmitters are programmed or re-programmed. The remote/keyless entry module can store up to four transmitters in memory.
Nov 2, 2009 at 10:21 PM
