1994 Lincoln Continental changing the water pump
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
JESTER1594
need to know how to replace the water pump
Nov 12, 2008 at 5:30 AM
BMRFIXIT
  • 19,053 POSTS
3.8L V6 - 1994 Lincoln Continental
WATER PUMP
Removal
1.Disconnect negative battery cable. Drain cooling system. Raise and support vehicle. Remove lower nut on both right-side engine mounts. Raise and support engine.
2.Remove accessory drive belts and water pump pulley. Remove air suspension pump (if equipped). Remove power steering with hoses attached and secure aside (if equipped).
3.Remove A/C compressor front bracket, leaving compressor in place (if equipped). Disconnect necessary coolant hoses. Remove water pump bolts and nuts. Note bolt location. Note if sealant is applied to bolt threads. Remove water pump and gasket.
CAUTION :When bolt is removed, note if sealant is applied to threads. Some bolts are coated with sealant to prevent coolant leakage.
Installation
1.Install gasket using Gasket and Trim Adhesive (D7AZ-19B508-B). To complete installation, reverse removal procedure. Lightly oil threads of bolt and stud not containing thread sealant.
2.If bolts originally contained thread sealant, clean and reapply thread sealant to bolts. Tighten bolts and nuts to specification.
Fill cooling system.
good luck
Need a tool or a tester CHECK IT @
https://www.2carpros.com/affiliate/uid/bmrfixit_1
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 15, 2008 at 2:54 PM
