1993 Lincoln Continental Valve Cover gaskets
1993 LINCOLN CONTINENTAL
120,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKE2009
  • 20 POSTS
How do i change my valve cover gaskets on my 1993 lincoln continental executive series
Jan 11, 2009 at 1:45 PM
BILLYMAC
  • 2,204 POSTS
hi mike. this looks harder then it actually is. first take the plantum off 10 mm bolts holding it on.set plantum aside now you can see the bolts holding xc on remove them. remove cover clean both v/c and head thouroughly.put rtv sealer on valve cover only. install new gasket, and reinstall cover . once your plantum is out of the way you have a perfect view, good luck .billymac
Jan 14, 2009 at 9:47 AM
