1993 Lincoln Continental Air suspension
58,807 MILES • 6 CYL • FWD • AUTOMATIC
JASIYAH
Recently i notice i had a leak in front left air shock. So i had the front shocks converted to non-air shocks. I didnt have a problem with the rear shocks until now. the rear shocks dont work at all now. Do the front and rear air shocks work independently of each other?
Is it something disconnected that i can connect myself?
Aug 18, 2010 at 2:19 AM
BLUECOLLAR
  • 86 POSTS
The problem with doing "just" the front is that when the air suspension module doesn't "see" anything changing in the front within 90 seconds, it'll turn the check suspension message on and shut down the system and not even try to do anything to the rear. When the message comes on, NO adjustments will be made.
The only real alternative you have is to convert the rear.
Aug 19, 2010 at 2:03 PM
