1992 Lincoln Continental struts
1992 LINCOLN CONTINENTAL
WRESTLERGRL18
Shakes or Wobbles problem
the struts blew and im tring to find how to change them and cant can anyone help by telling me how or showing me a sight with instructons?
Jan 16, 2010 at 3:54 AM
WRESTLERGRL18
i have everything i need except the know how and when i call and talk to guys they are rude tell me to take it to someone
Jan 16, 2010 at 4:13 AM
WRESTLERGRL18
[quote:48d7039e1a="merlin2021"]Go here for conversion kits and parts and technical help by phone.
http://www.americanairsuspension.com/[/quote:48d7039e1a]
i have the kit and when i call the guys are rude and tell me i need to take it to someone
Jan 16, 2010 at 4:19 AM
MERLIN2021
  • 17,250 POSTS
OK sorry about that, they must want you to buy their parts i guess! Is it the front or rear struts you need help with? And have you ever done struts on ANY car before? These are much harder than the average person has the talent or tools to do, but I will post the info with this warning, Support the car on a lift, or by the body with stands, air suspensions can emty while you get pinned under the car, and I wouldnt want that!
Jan 16, 2010 at 4:34 AM
WRESTLERGRL18
[quote:4928e1d56e="merlin2021"]OK sorry about that, they must want you to buy their parts i guess! Is it the front or rear struts you need help with? And have you ever done struts on ANY car before? These are much harder than the average person has the talent or tools to do, but I will post the info with this warning, Support the car on a lift, or by the body with stands, air suspensions can emty while you get pinned under the car, and I wouldnt want that![/quote:4928e1d56e]
i have not done it alone. i had help when i did it and i know its hard but i dont have another choice and thank you for the warning
Jan 16, 2010 at 4:55 AM
MERLIN2021
  • 17,250 POSTS
OK check your email, I sent all info on installing suspension parts on your car, I will tell you that this car REQUIRES a ford Rotunda Super Star II to command the system to fill...Check the height sensor link on affected axle, the arm may have poped off, this causes the air springs to empty, and the compressor will not run...
Jan 16, 2010 at 5:04 AM
