Air ride system was replaced with struts off of a Ford Taurus. Need to know how to override the electrical system so it doesn't show errors.
Dec 11, 2007 at 3:36 AM
AUTUMNH
MEMBER
in the trunk of your vehicle on the left side there should be a flap that has some velcrow on it pull that back and there should be 2 switches in there not marked. there is one that is sort of a push button that is the fuel reset in case of an accident the actual flip switch should be the air suspension. if the switches are not there they are under the passenger side dash. hope this helps
Dec 13, 2007 at 10:49 AM
NDDUNC
✓Experienced Mechanic
hey ,gateguy . i need to know what year[s] taurus those struts came from.i have a 92 cont.any info would be helpful.thanks! nddunc@scrtc.com
