1992 Lincoln Continental Air Ride
140,000 MILES • 6 CYL • FWD • AUTOMATIC
POTENT9901
I punctured my passenger air bag. It is effecting my air ride. Can I replace just the one that is punctured or do I have to replace both in the front susspension?
May 28, 2008 at 6:26 AM
BLUECOLLAR
  • 86 POSTS
Did you actually "puncture" a hole in the air bladder?...or is it just leaking? If you punctured a hole somehow, you can replace just one with no problem. If the bladder just plain leaks, you "can" replace just one, but unless the other had been replaced in the past, the two are the same age and the other WILL need replacing soon.
An option is to take the air completely and install a coil conversion kit.
Good Luck
Jun 3, 2008 at 11:11 AM
