1990 Lincoln Continental repair of solenoid value on air sh
1990 LINCOLN CONTINENTAL
43,000 MILES • 6 CYL • FWD • AUTOMATIC
DOUGLAS MCGILL
I have the right rear air bag going down with an audible leak intermit that I believe is coming from the solenoid valve. I have not been able to verify the location for sure cuz it only does it part of the time and when I have the wheel off to check it it does not leak. How do I remove this solenoid and repair it with the new o ring kit I got from Arnott industries? Thank you.
Aug 6, 2010 at 10:14 PM
BLUECOLLAR
  • 86 POSTS
Unless the solenoid has been removed before, most likely the leak is coming from the air strut itself.
I recommend doing the coil conversion, as the rear air struts are going to be discontinued shortly.
Aug 19, 2010 at 9:10 PM
