1989 Lincoln Contennential No Charging.
M93921
I have replaced the alternator/voltage regulator/battery. The battery is not getting current from the alternator, I have checked all fuses and all are good. I have heard about fusible links but I have not been able to find the one for the charging system. I have verified that the alternator is good and have replaced the voltage regulator again. Any help would be appreciated. Thank You
Jul 24, 2007 at 7:44 AM
JOHN67
i have an 1989 towncar that had the same problems and repaired all the same things you did with no help so i call my brother (electrical eng.) and with a little help from radio shack the problem fixed. follow your wiring from the alt you are looking for a resistor inline to the gauge that execites the alt. mine was in a blue rubber square piece.my manual didn't show mine
good luck
Feb 12, 2008 at 9:48 AM
