Hello, I have a lincoln continental 1988 3.8 engine. My problem is that the engine wont start regurlarly at startup, in order to start starting fuel of regular fuel has to be sprayed into the intake then it will turn on and run normarly. If fuel is not added then the engine wont start. Does this car uses a starting or cold start injector if yes where is located at.thanks
Feb 20, 2010 at 3:32 AM
