1985 Lincoln Continental IDLING
MARIANO63
Engine Performance problem
1985 Lincoln Continental V8 Two Wheel Drive Automatic 67000M miles
when i start the car in morning it starts ok but when i start driving for a few minuite and begin to reduce speed to stop, the engine start acelerating and speeding up without touching accelerator so i have too apply brakes hard until it stops and then i put it in park and i can tell that idle speed is very high. it is a 5 liter efi engine. let me know as soon as possible and if your solution works i will make a donation for sure .thanks nick
Sep 10, 2010 at 8:50 AM
  • 75,988 POSTS
Hi mariano63, Welcome to 2carpros and TY for the donation
Clean out the idle air control valve and also the throttle plate and check the accelerator linkage/cable and also test the throttle position sensor-
Sep 10, 2010 at 8:58 AM
