1982 Lincoln Continental
120,000 MILES • V8 • 2WD • AUTOMATIC
ZARIFA
Have overhauled 302 CID engine - replaced camshaft & lifters, had heads rebuilt, replaced timing chain & sprockets, etc. Compression test passed: 150/155/155/155/160/165/170/180 PSI, #1 -> #8 in order. Started on second try, seemed OK except for a ticking noise suspected to be lifter(s). Moved vehicle a short distance. Now makes pop or bang noise every couple of seconds and will not idle. Have replaced spark plugs, added gas treatment and injector cleaner to gas tank, no improvement. Will repeat compression test tomorrow.
Jan 5, 2009 at 5:25 PM
SERVICE WRITER
  • 9,123 POSTS
HAve you checked timing since the change in performance?
Jan 11, 2009 at 12:24 AM
ZARIFA
Dear Service Writer,
My boyfriend said he wouldn't check the timing because you can't change the timing.
I think this is great that you are using your experience to help people. I wish the car could be repaired. It is taking so many weekends.
Please help.
Zarifa
My cell phone is 858-610-8702. I'm at his houe/ If you call you can talk to him. Thank you,
Zarifa
Jan 11, 2009 at 1:21 AM
SERVICE WRITER
  • 9,123 POSTS
I understand that it is computer controlled, but that doesn't mean that something mechanically didn't happen to make the timing go off.
It is provding a clue to what is going on.
IF there is good spark, proper fuel pressure and the compression is right...that leaves timing as a possible issue.
Say for example the timing chain jump a tooth..( I know it was just rebuilt and all), but it is still possible. It could cause this. Maybe the ticking was coming from the timing chain area.
Jan 11, 2009 at 2:45 AM
ZARIFA
Checked compression again. All cylinders are between 135 and 155 PSI, slightly lower than the initial compression test.Fuel pressure seems OK. I have removed the fuel injectors and checked the valve needle (pintle) on each one. In one, the pintle moves about .015" and in the other one it moves about .003". I think the two injectors should have nearly identical stroke distances. If the injectors fire alternately, that difference would account for the engine running unevenly. I have not found any specification either in the Ford service manual or on the Internet for the correct distance, so I don't know if .015" or .003" is right, or if they're both wrong. I intend to replace both injectors; if one has gone bad there is no telling how long the other one will last.
Jan 11, 2009 at 10:43 AM
ZARIFA
This is where Dave wrote you a message.
Thank you for your kind response. Dave wrote yu a message in the topic rreview window. I think he should have written it in this window because another weekend is gone and the car still isn't fixed. You are the only one helping us.
Bye for now,
Zarifa
858-610-8702
Jan 11, 2009 at 11:23 AM
SERVICE WRITER
  • 9,123 POSTS
The only way I could tell on the stroke length is to compare to a new one. I don't have anything on that either. Mitchell1 doesn't offer anything on this car.
Your logic sounds good.
Are there any codes?
Using Voltmeter
The service codes can be interpreted using a voltmeter. These codes will appear as a fluctuation of the needle, indicating the first digit of the code, followed by a two second pause, then a second series of pulses indicating the second digit of the code. For example, a code 3-2 would be indicated by three pulses, a two second pause, then two more pulses. If more than one code is indicated, there will be a five second delay between codes.
Using STAR Tester
After connecting STAR tester, the tester will run a display check as follows: The numerals 88 will begin to flash in the display window, followed by a steady 00, which indicates that the tester is ready to start the Self Test and receive service codes.
To receive service codes, press the push button at the front of the tester. The button will latch downward and a colon will appear in the display window in front of the 00 numerals. The colon must be displayed to receive service codes. If the Lo-Bat indicator shows steadily during operation of tester, turn power switch Off and replace the unit's nine volt battery
Jan 12, 2009 at 3:13 AM
