Goes into limp mode when accelerating?
152,223 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
WHITING2416
  • 22 POSTS
New throttle body and accelerator pedal and the problem still occurs. Car idles fine in park as well as revving. When I go into drive it's fine. It's only when I press the pedal down rapidly in drive it does this. I can very slowly accelerate and it's ok but it's too slow to being pulling out in traffic.
Aug 19, 2023 at 3:10 AM
  • 110,248 POSTS
The light that turned on, is that a skid control light? Sorry, it's blurry when I watch it. Also, have you scanned for diagnostic trouble codes? Are there any presents and if so, could you let me know?
As far as scanning, you should be scanning the can-bus. CAN stands for controller area network.
Basically, all the different modules are tied together via a few wires. This type of scan retrieves codes regardless of the module storing them.
Here is a link showing how it's done:
Let me know as much as you can.
joe
Aug 19, 2023 at 2:14 PM
WHITING2416
  • 22 POSTS
Main codes were for throttle body and pedal position sensor. Some for O2 sensors and 1 for emissions (fuel cap). I did a relearn process and nothing changed but someone told me to drive it around and so I did. I probably drove about 10 miles and now it no longer does this, for now. I think it might be fixed. Thank you! And yes, that was the traction and ABS light. It comes on every time a chevy goes into reduce engine power mode.
Codes:
P2135, P013E, P0036, P0455, P2135, P0141.
Aug 24, 2023 at 4:37 AM
  • 110,248 POSTS
Thanks for the update. It sounds like the problem has been resolved. That's good news. If anything changes, let me know.
Also, feel free to come back anytime in the future. You are always welcome here.
Aug 24, 2023 at 12:43 PM
