Limp Mode, no check engine light?
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
ARHAKES
RPM tops out 2,500, reduced speed.
Sep 19, 2022 at 1:44 AM
  • 55,694 POSTS
This is common when the throttle body needs service. here is a guide to help show you what to do with instructions in the diagrams below to show you how on your specific car. Please go over the guide before you begin.
#3 is the location of the throttle body. Check out the images (below). Please let us know what happens.
Sep 19, 2022 at 10:29 AM
SQM
  • 6,383 POSTS
One of the common cause for limp mode is having a dirty throttle actuator. A dirty actuator won't be able to provide correct data to the ECM and that can trigger the limp mode.
Many times cleaning out the throttle actuator can help.
Also, have you tried to disconnect the battery and see if that resets it?
Take a look at this guide:
https://www.2carpros.com/articles/reduced-power-limp-mode
Let me know what you find or of any questions.
Sep 19, 2022 at 10:31 AM
