Limp Mode, p0882 Code etc?
260,000 MILES • 4WD • MANUAL
ERICLOLIS0
Limp mode, hesitation or misfire, p0882, blown pcm/trans fuse
May 24, 2026 at 7:58 AM
  • 55,711 POSTS
Hello, So the code P0882 means the transmission control circuit is seeing low voltage. If the PCM/transmission fuse is blowing, the truck is likely going into limp mode because the transmission control power feed is being lost. Also I would do a tune up for the misfire which can affect engine vacuum which can make the transmission shift late. I have seen a shorted shift solenoid cause this problem but you should look at the transmission wiring harness as well. To help check it unplug the transmission electrical connector and then replace the fuse and turn the key on to see if the fuse still bows, please let me know.
May 25, 2026 at 11:26 AM
