Car in limp mode. No reverse. Sometimes in the morning, reverse will work once or twice then it will not work. No check engine lights on. Drives but due to limp mode, it will not shift into third(?) gear.
ATF fluid level is okay.
Also, flushed ATF fluid from cooling line four days prior. Top off with same amount of Maxlife ATF. About 35,000 prior flushed out ATF using same procedure and maxlife ATF.
Aug 22, 2019 at 7:31 PM
