Limp mode?
175,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
JOHNJONES556
  • 5 POSTS
I replaced shift solenoid, TPS, distributor, and still at 2,000 RPMs and not going faster than 20 MPH I'm just trying to figure the cause and fix it.
Nov 2, 2024 at 2:08 PM
  • 110,248 POSTS
This can be a few different things. If you have the vehicle in park, can you rev it past 2,000 RPMs? Also, are you sure the catalytic converter isn't plugged?
Look through this link and let me know if anything mirrors your experience:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Have you checked to see if there are diagnostic trouble codes stored? If you haven't checked, I recommend doing so.
Nov 2, 2024 at 3:07 PM
JOHNJONES556
  • 5 POSTS
In it does fine but there's it will still do it in park but not often. I can't check it even though it's obd1 but it has an obd2 port.
Nov 2, 2024 at 3:32 PM
JOHNJONES556
  • 5 POSTS
In park.
  • 55,711 POSTS
Okay, so is the transmission not shifting gears or does the engine just have low power? What codes did you get, and did you check the catalytic converter?
Nov 4, 2024 at 12:43 AM
JOHNJONES556
  • 5 POSTS
Loss of power won't shift out of first and I cannot get the codes due to OBD2 port OBD1 system.
Nov 4, 2024 at 12:46 AM
  • 55,711 POSTS
Okay, let's get the codes by doing an OBD1 code gather, this guide will show you how:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Please go over this guide and get back to us.
Nov 4, 2024 at 2:23 AM
