Stuck in limp mode
220,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
MELVIN HEAD
Codes reported bad crank and cam sensor. replaced crank and cam. then report other cam sensor bad.
Sep 21, 2019 at 9:12 PM
Can you provide the actual codes? Can you tell me which codes you had and then which codes you have now?
I just want to get caught up to where you are with this and there could be something in common with all of them.
Lastly, let me know if you just purchased this vehicle or if it has been fine then this happened? Just looking for a little history on when the limp mode happened.
Thanks
Sep 22, 2019 at 4:21 AM
