Limousine
150,000 MILES
TWILIGHTLIMO
Tread wear on front tires on outside very quickly ,new tires will last only 1,000 miles then ruined. always have limo aligned every 6 months but no luck they say they have maxium toe in. Is there a kit to fix this problem? thanks
Apr 28, 2013 at 12:15 AM
maximum toe???
i would be more concerned about the camber. what are the reading????
i would also go to another place to have the alignment re checked.
Apr 28, 2013 at 12:22 AM
WRENCHTECH
  • 20,760 POSTS
Toe in will give you faster edge wear than Camber will but it's "toe-in" that give you outside edge where so I'm a little confused as to why they claim maximum toe in. Less toe in is what would improve that situation. Toe in causes scrubbing from the outside in.
Apr 28, 2013 at 12:47 AM
