Idling up and shutting off?
191 MILES • 4.7L • V8 • TURBO • AUTOMATIC
PPJOHNSON3
Iling up and cutting off. Vehicle listed above is the Limited model.
Jan 9, 2021 at 4:53 AM
Can you give a little more detail on what is happening? Does this happen when you first start the vehicle or is this while driving?
Here are some guides on stalling at idle as that is what I am assuming:
https://www.2carpros.com/articles/stall-at-idle
If this is happening when it first starts, then we need to check the fuel pressure while this is happening and that will help figure out if that is the issue.
Let's start with this and go from there as I am sure this info will get us a better idea on next steps. Thanks
Jan 10, 2021 at 6:40 AM
