Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Trouble Codes
P Codes (Powertrain)
P0100 - P0199
P0100
Limit power, multiple codes
2005 FORD F-150
237,238 MILES • 4.6L • V8 • 2WD • AUTOMATIC
DARRELLSIMPSON26
MEMBER
1 POST
P2106
P0121
P0221
P0222
P0223
P0100
Jul 20, 2019 at 5:12 AM
Experienced Mechanic
Yep this is a common problem when the throttle actuator needs to be serviced we just had the same problem this video will help you fix it.
https://youtu.be/6fWYjfU9UV8
Jul 21, 2019 at 9:43 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
