Leaking oil
167,885 MILES • 1.6L • 3 CYL • 2WD • MANUAL
MR MAKHWASA
I find leaking oil under the car this morning. When I check the oil level is fine.
May 22, 2019 at 5:14 PM
SCGRANTURISMO
  • 4,897 POSTS
If your leaking oil from under your vehicle can you tell is it coming from the bottom of the engine (possible spots are rear main seal, front main seal, oil pan, oil sending unit) or from the top of engine (valve cover gasket, head gasket, timing chain cover, oil filter)? Also if you could take a picture that would help us diagnose where it's leaking from.
Thanks,
Alex
2Carptos
May 23, 2019 at 1:20 AM
