headlights staying on
150,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
FLYNN-T
  • 35 POSTS
went for a drive and came back home and when I got out noticed headlights were still on even with keys in my hand. I put emergency brake on to see if the daytime running light module was gone but they still did not go out. looked at the clusters of relays but cannot figure out which one runs the light. can you show me which relay it is or help me figure out what the problem could be? thank you
Apr 26, 2017 at 4:32 AM
HMAC300
  • 48,601 POSTS
there are no relays for the lights, so it is either a switch or maybe dimmer switch if mounted on floor. start with the switch first.
Apr 26, 2017 at 5:22 AM
FLYNN-T
  • 35 POSTS
it was daytime and I never pulled the light switch on but they come on once I start driving. is that the switch or is it another one you are talking about? thank you
Apr 26, 2017 at 5:40 AM
FLYNN-T
  • 35 POSTS
So there are no relays to run the headlights?
Apr 26, 2017 at 5:52 AM
HMAC300
  • 48,601 POSTS
not on your model car and it may be the headlight switch unless it is a wiring issue.
Apr 26, 2017 at 6:04 AM
FLYNN-T
  • 35 POSTS
The head light switch I pull out at bottom of dash or the switch on the steering column that also has the signal light switch in it. thanks for the help.
Apr 26, 2017 at 6:11 AM
FLYNN-T
  • 35 POSTS
Just changed the one on the column but still the same thing, lights are still on.
Apr 26, 2017 at 7:20 AM
HMAC300
  • 48,601 POSTS
the headlight switch is the one you pull out to make the headlights work.
Apr 26, 2017 at 8:04 AM
FLYNN-T
  • 35 POSTS
okay thanks, I will change it in the morning starting to get dark here now.
Apr 26, 2017 at 8:23 AM
FLYNN-T
  • 35 POSTS
is the daytime running light module in the headlight switch also or is it located some where else-thankyou
Apr 26, 2017 at 8:49 PM
FLYNN-T
  • 35 POSTS
Just changed the switch you pull out to put headlights on same thing the lights still stay on. so I have changed switch on column and the one you pull to put lights on and still have not got it. lights still stay on all the time. Thanks
Apr 26, 2017 at 10:27 PM
HMAC300
  • 48,601 POSTS
well then your module is bad we do not know if you have DRL's or not so we have to go with a basic system. but instead of changing parts to find the problem have it scanned to make sure the DRL is bad trouble is with your old system you'll have to find someone that can scan that old system.
Apr 26, 2017 at 10:30 PM
FLYNN-T
  • 35 POSTS
where is this module located mine shadow is a 1993 but I also have a 1994 the whole car for parts. Thanks
Apr 26, 2017 at 11:02 PM
HMAC300
  • 48,601 POSTS
it might need to be programmed to your car if so a mechanic will have to do it. it is on the fender shield near left end of bumper on a 1993 on a 1994 it is on left inner fender panel above wheel well.
Apr 27, 2017 at 12:08 AM
FLYNN-T
  • 35 POSTS
so what will I do try it first to see if it works and then if it does not take it and get it programmed or just take it and get it programmed first? thanks for the help.
Apr 27, 2017 at 12:49 AM
HMAC300
  • 48,601 POSTS
try it first.
Apr 27, 2017 at 2:25 AM
FLYNN-T
  • 35 POSTS
Thanks for the help, appreciate it, it was the daytime running light module as soon as I changed it lights went out and is working properly. Thanks again.
Apr 27, 2017 at 7:03 AM
FLYNN-T
  • 35 POSTS
if I unhook each relay one at a time will that let the headlights go out and tell me that is the one that is bad-by unplugging them one at a time and plugging them back in if they do not go out.
Apr 29, 2017 at 8:46 AM (Merged)
HMAC300
  • 48,601 POSTS
could be a bad headlight switch as well or a wire that has worn through touching something to make them stay on. but if you unplug the relay and they go out it may be the problem. try switching with another relay see if it still happens.
FLYNN-T
  • 35 POSTS
there is a dozen of relays in a cluster not sure which one it is, but if I keep trying them when I unplug the right one the lights should go out right?
HMAC300
  • 48,601 POSTS
our schematic does not show any relays for a 1993 shadow.
FLYNN-T
  • 35 POSTS
there is a cluster of what I think is relays in one spot but you mean there are none for the headlights right? thanks
Apr 29, 2017 at 8:47 AM (Merged)
  • 55,649 POSTS
Yes none are for the headlight, try unplugging the switch to see what happens, if they go out replace the switch.
Best, Ken
