Intermittently, when my engine is running, all turned-on lights will pulsate (brighten then dim) repeatedly?
270,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JOSUE RODRIGUEZ2
  • 23 POSTS
Sometimes it's only the headlights and other times it's every light that's on. I thought it was the alternator but when I got it checked at AutoZone, they said that my battery and alternator were in the clear. I watched a couple YouTube videos and learned that it could be the voltage regulator or a bad ground somewhere. But since the voltage regulator is inside the alternator maybe it's alright. Any advice would be great.
Thanks!
Mar 30, 2024 at 2:45 PM
  • 55,743 POSTS
Yes, this can happen when the ground from the battery to the chassis or the ground from the battery to the engine is no good. I would run a jumper wire while the engine is running, and the lights are on to see if it makes a difference. If not, the alternator is bad and the auto parts store can't tell. Here is how to replace the alternator correctly in case you need it.
ALTERNATOR
Removal and Installation
REMOVAL
1.Disconnect the battery cable from the negative terminal.
CAUTION:
To prevent damage to the parts, disconnect the battery cable from the negative terminal first.
2.Remove air duct (inlet). See: Air Cleaner Fresh Air Duct/Hose > Removal and Replacement > Exploded View.
3.Remove reservoir tank. See: Radiator > Removal and Replacement > Exploded View.
4.Disconnect alternator harness connector.
5.Remove "B" terminal harness nut, and then disconnect "B" terminal harness.
6.Remove alternator mounting bolt (upper).
7.Remove engine under cover. See: Interior Moulding / Trim > Removal and Replacement > Exploded View.
8.Remove front wheel RH.
9.Remove splash guard RH. See: Front Fender Liner > Removal and Replacement > Removal And Installation.
10.Remove drive belt. See: Drive Belt Tensioner > Removal and Replacement > Removal And Installation.
11.Remove idler pulley. See: Drive Belt Tensioner > Removal and Replacement > Removal And Installation.
12.Remove compressor mounting bolts, and then move compressor to secure work space. See: Compressor HVAC > Removal and Replacement > Exploded View.
CAUTION:
Never disconnect low-pressure flexible hose and high-pressure flexible hose from compressor.
13.Remove water pipe mounting bolts, and then move water pipe to secure work space. See: Oil Cooler, Engine > Removal and Replacement > Exploded View.
CAUTION:
Never disconnect water hose from water pipe.
14.Remove return tube fixing clamps, and then move return tube to secure work space. See: Power Steering Line/Hose > Removal and Replacement > Exploded View.
CAUTION:
Never disconnect return tube from return hose assembly.
15.Remove alternator mounting bolt (lower) and alternator mounting nut (lower).
16.Remove alternator from the right side of the vehicle.
CAUTION:
Be careful not to contact with and damage surrounding parts when removing alternator from the vehicle.
INSTALLATION
Note the following items, and then install in the reverse order of removal.
CAUTION:
- Temporarily tighten all of alternator bolts and nut. And then tighten them in numerical order shown in the figure.
- Install alternator, and check tension of belt. See: Drive Belt > Procedures > Checking Drive Belt.
- Be careful to tighten "B" terminal nut carefully.
- For this model, the power generation voltage variable control system that controls the power generation voltage of the alternator has been adopted. Therefore, the power generation voltage variable control system operation inspection should be performed after replacing the alternator, and then make sure that the system operates normally. See: Charging System > Initial Inspection and Diagnostic Overview > Inspection Procedure.
Check out the images (below). Please upload pictures or videos in your response to the problem so we can see what's going on.
Mar 31, 2024 at 12:12 PM
JOSUE RODRIGUEZ2
  • 23 POSTS
Good morning Ken,
I got my alternator swapped twice now and it keeps doing the same thing. Once with a new one and the other with a used one. I cleaned up the battery terminals, the wire that goes from the negative terminal to the transmission, the alternator holes, bolts, nuts, and mounting piece (not that they were corroded), and applied grease to them but the problem persists. I don't have a check engine light on so I don't have that lead. I watched more videos and they said any bad ground can cause it. So now I'm on the hunt for all grounding wires on the car. Do you know where these grounds are? Or if I'm on the right track?
Thanks again.
Oct 12, 2024 at 1:06 AM
  • 55,743 POSTS
It will only be the ground wires to the engine/transmission and to the chassis to the battery, I would check those first. These need to be clean and tight for a good connection.
Oct 13, 2024 at 2:08 AM
