The air bag light is on and will not turn off, how do I reset it?
113,162 MILES • 2.2L • 6 CYL • 2WD • MANUAL
LEVICAR
Air bag light is on and won't go off how do I reset it?
Aug 29, 2023 at 1:24 AM
  • 55,711 POSTS
You must fix the problem with the airbag system before the light will go off, it is probably the spiral wire that has gone bad but to be sure let's run the codes, this guide will help:
https://youtu.be/gnSGfEqrf_w?si=bL-8Js6Lu6cTsgNV
Please let us know how it goes.
Aug 29, 2023 at 9:49 AM
