lights on, car wont shift
2003 CHEVROLET
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
MELISE71188
My 2003 Chevy Trailblazer has all the lights on ABS and all, and says to check brake s system but it has fluid and all, nothing's wrong with the brakes. Also won't shift automatically, I can do it manually but it's still rough. Also the speesometer jumps all over the place
Jan 21, 2016 at 12:57 AM
HMAC300
  • 48,601 POSTS
check battery for condition including load test and whether or not terminals are clean. then have it scanned for codes.
Jan 21, 2016 at 1:47 AM
WRENCHTECH
  • 20,760 POSTS
It's the ABS module that you have to get scanned, not the engine module. It sounds like there is a problem with one of the speed sensors but the codes will tell you that. Do the scan before messing with the battery cables because you might just erase the codes if you lose the battery connection momentarily.
Jan 21, 2016 at 1:55 AM
