lights not working
180,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
DOUG125
No headlights no directionals no breaklights high beams not working changed hazard switch directional switch brake switch and headlight switch running lights work front and back everything was working stopped working thinking its bcm
Mar 27, 2016 at 12:16 AM
HMAC300
  • 48,601 POSTS
check fuses under hood fuse box as well as relays.if you have then get it scanned for codes auto parts cannot do this
Mar 27, 2016 at 12:26 AM
DOUG125
Thank you checked all fuses and relays all good
Mar 27, 2016 at 2:42 AM
  • 55,658 POSTS
Hey Doug125,
If all fuses and relays are good, the BCM is our next choice, they did have problems with them on this car btw.
Apr 4, 2016 at 6:38 AM
