Lights flashing on and off on dash
88,000 MILES • 1.4L • 3 CYL • 2WD • MANUAL
LAURENH2294X
When I drive my car after about twenty minutes the oil light flashes on saying ‘oil pressure fault stop now’. About five minutes later my temperature light comes on and the dash says ‘temperature fault stop now’. They don’t stay on permanently they little flash on and off along with the bleeping noise. It seems to happen mostly when I’m stopped e.g at lights. I’ve checked my oil which is fine, also checked which seems fine, but I do feel it drains quicker than it usually should, I put water in it every other day. Does anyone have any idea what these problems could be? Could it be my sensors are on the blink? Or something more sinister? Thanks in advance.
May 17, 2019 at 2:56 AM
  • 55,688 POSTS
It sounds like you have low oil pressure. has the car being maintenance regularly? because if not you can have a clogged oil pump pick up screen. I would try changing the oil and looking for coolant leaks. here are two guides to help us find the problem:
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
and
https://www.2carpros.com/articles/car-is-leaking-coolant
May 20, 2019 at 6:16 AM
