One brake light and all turns signals are not working
253,000 MILES • 2.0L • 6 CYL • 2WD • AUTOMATIC
KENWEST
Have no turn signals, one brake light out.
Aug 3, 2020 at 3:01 PM
BMDOUBLE
  • 1,139 POSTS
The brake lights and turn signals are controlled by the smart junction box. If there is a blown bulb sometimes the module will protect itself by disabling these circuits. What I've done in the past is replace the bad bulb/s, disconnect the battery for 3 minutes, then things should work again. If it does not operate still, you'll need a scan tool that can retrieve smart junction box codes, then we can go from there.
Aug 4, 2020 at 5:55 AM
