Lights flicker in off position
179,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVISBOI88
Headlights in off position but lights keep flickering. What do you think it could be
Sep 22, 2019 at 6:42 AM
94 TRANSAM
  • 680 POSTS
Hi Davis, Welcome to 2CarPros.
What you describe is likely the DRL (Day time running lights) failing. There is a DRL module under the dash that is basically just a diode. As it ages the voltage drops to the head lights and they flicker. A simple diode test will tell you if it is bad.
Below is a diagram of the circuit.
Rich
Sep 22, 2019 at 3:44 PM
