Checked for current none only ground. checked fuses okay checked wires for breakage couldn't fine any. I am confused.
Jan 16, 2019 at 8:27 AM
SCGRANTURISMO
✓Experienced Mechanic
Hi Verna, my name is Alex and I will be helping you today. Sounds to me like you might have a faulty bulb. Here is a helpful link about fast blinking turn signals and how to fix them. Hope this helps.
Thank you for answering my problem. But, I have checked bulbs. there is no power to right rear for brake and turn signal only park light on right rear and front right signal that blinks fast, left side lights are okay.
Jan 16, 2019 at 10:16 PM
SCGRANTURISMO
Hi Verna, are your license plate lamps working?
Jan 17, 2019 at 3:37 PM
VERNALEWIS
MEMBER
Yes.
Jan 17, 2019 at 7:43 PM
DANNY L
Hello, I'm Danny.
I'm just adding this diagram to help . This is for the rear lights to help check the circuit.There are more diagrams we can offer you. Hope this helps and thanks for using 2CarPros.
Danny-
Image (Click to enlarge)
Jan 17, 2019 at 8:55 PM
VERNALEWIS
MEMBER
Thank-you, Danny. For the right side there is no power at brake switch only for left. So i jumped switch, brake light works. There are two relays for the left tt relay. you can hear or feel the right light relay nothing. can't fine signal flasher sounds like it is in the multi-switch. there is power and ground at the right tt relay.
Jan 21, 2019 at 10:02 PM
SCGRANTURISMO
Hi Vernal, it's Alex. Great to hear your running the problem down. Is there anything else we can do to help?
Jan 22, 2019 at 1:24 PM
VERNALEWIS
MEMBER
IS there any way i can bypass? shouldn't there be flashing signal coming from multi-switch on a wire?
Jan 22, 2019 at 8:54 PM
SCGRANTURISMO
Hi Vernal, Here is a wiring diagram with the hazard switch in it. I hope this helps. Let me know if there anything else we can do for you. Thanks, Alex.
Jan 23, 2019 at 6:00 AM
VERNALEWIS
MEMBER
Thanks Alex,The diagram was to blurry for me to read.could i get another showing from the front to rear. thank-you
Jan 26, 2019 at 9:11 PM
SCGRANTURISMO
Hi Vernal, Here are the wiring diagrams you requested. I hope this helps. Thanks.
Images (Click to enlarge)
Jan 27, 2019 at 3:49 PM
VERNALEWIS
MEMBER
Will guys i'm back for more help. thank you for everything. I have got a short i believe with negative. Terminal off and test light connected to battery negative and negative. Cable tester lights. so i removed power wire from battery. Positive to pdb .and ran a new wire, still a short until i disconnected wires from brake master cylinder. Replaced power to pdb again test light came back on even with brake master plug still removed.wire from BCM flashes fast. thanks for your help.
Feb 19, 2019 at 5:47 AM
This sounds like a BCM failure to me but to be sure lets rung down the wiring diagrams flowing this guide:
Check out the diagrams (below). Please let us know what happens. If the BCM is bad you will need to get it programmed which will run about $130.00 at a shop.
