Also, my brake lights only work when I’m in park, but not while I’m driving.
Mar 16, 2024 at 7:56 AM
✓Experienced Mechanic
This happens when the flasher is starting to go out. Here is the location of the flasher so you can change it out. Check out the images (below). Please let us know what happens.
Image (Click to enlarge)
Mar 17, 2024 at 4:08 AM
RODJAMES
MEMBER
I meant to say the passenger side of the brake lights doesn’t work while the driver side does.
Mar 18, 2024 at 2:44 AM
Yep, this will still be the flasher, I would swap it out to fix the problem.
