Lights
162,467,000 MILES • 2WD
ALAYSHA 1
My headlights goes on and off what that could be ?
Jan 10, 2016 at 10:48 AM
ALAYSHA 1
How can I check?
Jan 10, 2016 at 10:50 AM
PACO8224
  • 117 POSTS
Is it both headlights that do that? Or just one side?
Jan 10, 2016 at 11:07 AM
ALAYSHA 1
Both
Jan 10, 2016 at 11:20 AM
PACO8224
  • 117 POSTS
How long has this been going on? Can you make sure your fans are coming on
Jan 10, 2016 at 11:27 AM
PACO8224
  • 117 POSTS
Do they go off and you have to shut ignition off then on to make them come back on? Or do the flicker on and off while driving?
Jan 10, 2016 at 11:30 AM
ALAYSHA 1
It's just started n yes the fans are coming on n they just go off while I'm driving n won't come on until couple mins later
Jan 10, 2016 at 11:46 AM
PACO8224
  • 117 POSTS
Ok on the fuse box number 46 relay needs to be checked, that's your headlamp module and had a couple gone bad before. If you would like you can swap number 46 with number 45 relay just to verify.
Jan 10, 2016 at 11:53 AM
