Check engine light came on for a few weeks then it out and now it is back on again
2015 CHRYSLER 300
52,000 MILES • 2WD • AUTOMATIC
ASHLEY ABRAM
my check engine light came on a few weeks ago, and said it was coolant issue. light went out and a few days ago it came back on and today it flashed running hot and the electronic throttle light came on.
Dec 18, 2016 at 11:47 PM
STEVE W.
  • 15,351 POSTS
You need to have it scanned to see what is actually happening. Usually the light does not come on and then go off unless the problem was repaired. It could be that it is a bad sensor or wiring, or it could have low coolant or other issue.
This should be covered under the five year/100,000 mile warranty if you bought it new.
Dec 19, 2016 at 12:20 AM
