Lighting and electrical
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
MHB1983
My driver's side front and rear lights will not work. Running, turn, brake and high beams. No front and rear driver's side lights. Is there a fuse or a group of fuses/relays that control just a certain side of the car's lighting?
Jul 26, 2018 at 6:25 AM
  • 55,711 POSTS
I would try cycling the emergency flasher switch multiple times to clean the contacts. Next there is an ACL relay that needs to be checked as well. Here is a guide and the running light wiring diagrams so we can test to see where you are losing power:
Cheers, Ken
Jul 29, 2018 at 6:22 AM
